주요 콘텐츠로 건너뛰기
Spin Master Boxer Wheel Gears Replacement
필요한 것
  1. Spin Master Boxer Wheel Gears Replacement, Robot Screen: 1 단계, 이미지 1개 중 1개
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Wheel Gears Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Wheel Gears Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Wheel Gears Replacement: 4 단계, 이미지 2개 중 1개 Spin Master Boxer Wheel Gears Replacement: 4 단계, 이미지 2개 중 2개
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Wheel Gears Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Wheel Gears Replacement, Robot Wheel Gears: 6 단계, 이미지 1개 중 1개
    • Place robot on back so that the sensors are facing up.
  7. Spin Master Boxer Wheel Gears Replacement: 7 단계, 이미지 2개 중 1개 Spin Master Boxer Wheel Gears Replacement: 7 단계, 이미지 2개 중 2개
    • Gently separate the left set of wheels from the inner portion of the circuit board, by gripping the wheels and pulling them away from main body of robot.
    • There are wires attached to each set of wheels, so be careful not to rip them apart.
    • Repeat the process for the right set of wheels.
  8. Spin Master Boxer Wheel Gears Replacement: 8 단계, 이미지 2개 중 1개 Spin Master Boxer Wheel Gears Replacement: 8 단계, 이미지 2개 중 2개
    • Use the Phillips #00 Screwdriver to remove the 3mm screw that connect the black wheels to the gears.
    • You will have to go through the black wheel to unscrew some of the screws.
  9. Spin Master Boxer Wheel Gears Replacement: 9 단계, 이미지 3개 중 1개 Spin Master Boxer Wheel Gears Replacement: 9 단계, 이미지 3개 중 2개 Spin Master Boxer Wheel Gears Replacement: 9 단계, 이미지 3개 중 3개
    • Grip wheel, and gently pull up, to separate white gear casing into its front and back panel.
  10. Spin Master Boxer Wheel Gears Replacement: 10 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, grip defective gear, and pull up and out of gear system to replace.
결론
작성자
4다른 기여자 명과 함께
Lauren Roide
회원 가입일: 04/16/19
739 평판
안내서 5개를 작성함
Cal Poly, Team S1-G1, Maness Spring 2019 Cal Poly, Team S1-G1, Maness Spring 2019 회원
CPSU-MANESS-S19S1G1
4 회원들
안내서 10개를 작성함
3가이드 댓글
This is super useful guide and picture are clear for the steps. Will be excellent to know where to buy these gears replacements?
Javier Perez - 답글
Hello. Thé motor seems to be broken. Do you Knowles ils spec to buy à New one.
Sorry, im french...
Tanks.
Jerome Carbonneaux - 답글
Do you know its spec to buy a new one?
Realy sorry...
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 48
전체 시간: 4,119
