주요 콘텐츠로 건너뛰기
Spin Master Hatchimal Draggle Fur Replacement
필요한 것
  1. Spin Master Hatchimal Draggle Fur Replacement, Plastic Wing Replacement: 1 단계, 이미지 1/1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Fur Replacement: 2 단계, 이미지 1/1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Fur Replacement: 3 단계, 이미지 1/1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: 4 단계, 이미지 1/2 Spin Master Hatchimal Draggle Fur Replacement, Fur Replacement: 4 단계, 이미지 2/2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Fur Replacement: 5 단계, 이미지 1/2 Spin Master Hatchimal Draggle Fur Replacement: 5 단계, 이미지 2/2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Fur Replacement: 6 단계, 이미지 1/3 Spin Master Hatchimal Draggle Fur Replacement: 6 단계, 이미지 2/3 Spin Master Hatchimal Draggle Fur Replacement: 6 단계, 이미지 3/3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Fur Replacement: 7 단계, 이미지 1/3 Spin Master Hatchimal Draggle Fur Replacement: 7 단계, 이미지 2/3 Spin Master Hatchimal Draggle Fur Replacement: 7 단계, 이미지 3/3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Fur Replacement: 8 단계, 이미지 1/2 Spin Master Hatchimal Draggle Fur Replacement: 8 단계, 이미지 2/2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Fur Replacement: 9 단계, 이미지 1/2 Spin Master Hatchimal Draggle Fur Replacement: 9 단계, 이미지 2/2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Fur Replacement: 10 단계, 이미지 1/3 Spin Master Hatchimal Draggle Fur Replacement: 10 단계, 이미지 2/3 Spin Master Hatchimal Draggle Fur Replacement: 10 단계, 이미지 3/3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Fur Replacement: 11 단계, 이미지 1/2 Spin Master Hatchimal Draggle Fur Replacement: 11 단계, 이미지 2/2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
결론
Kimberly Searles
회원 가입일: 02/14/18
340 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G5, Nance Spring 2018 USF Tampa, Team S1-G5, Nance Spring 2018 회원
USFT-NANCE-S18S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 755
