주요 콘텐츠로 건너뛰기
Spiral Bound Notebook Cover Replacement
필요한 것
  1. Spiral Bound Notebook Cover Replacement, Cover: 1 단계, 이미지 1/2 Spiral Bound Notebook Cover Replacement, Cover: 1 단계, 이미지 2/2
    • Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
  2. Spiral Bound Notebook Cover Replacement: 2 단계, 이미지 1/3 Spiral Bound Notebook Cover Replacement: 2 단계, 이미지 2/3 Spiral Bound Notebook Cover Replacement: 2 단계, 이미지 3/3
    • Uncoil the free end of the spiral.
  3. Spiral Bound Notebook Cover Replacement: 3 단계, 이미지 1/3 Spiral Bound Notebook Cover Replacement: 3 단계, 이미지 2/3 Spiral Bound Notebook Cover Replacement: 3 단계, 이미지 3/3
    • Push the spiral end back through the binding hole and pull it out.
  4. Spiral Bound Notebook Cover Replacement: 4 단계, 이미지 1/1
    • Repeat previous step until spiral is removed.
  5. Spiral Bound Notebook Cover Replacement: 5 단계, 이미지 1/1
    • Take the damaged cover and place it over the cardstock, aligning them at the edges.
  6. Spiral Bound Notebook Cover Replacement: 6 단계, 이미지 1/3 Spiral Bound Notebook Cover Replacement: 6 단계, 이미지 2/3 Spiral Bound Notebook Cover Replacement: 6 단계, 이미지 3/3
    • Trace the cover edges.
  7. Spiral Bound Notebook Cover Replacement: 7 단계, 이미지 1/2 Spiral Bound Notebook Cover Replacement: 7 단계, 이미지 2/2
    • Trace the cover binding holes.
  8. Spiral Bound Notebook Cover Replacement: 8 단계, 이미지 1/3 Spiral Bound Notebook Cover Replacement: 8 단계, 이미지 2/3 Spiral Bound Notebook Cover Replacement: 8 단계, 이미지 3/3
    • Using a hole punch, punch out the traced holes on the cardstock sheet.
  9. Spiral Bound Notebook Cover Replacement: 9 단계, 이미지 1/3 Spiral Bound Notebook Cover Replacement: 9 단계, 이미지 2/3 Spiral Bound Notebook Cover Replacement: 9 단계, 이미지 3/3
    • Cut off the traced edges on the cardstock sheet.
  10. Spiral Bound Notebook Cover Replacement: 10 단계, 이미지 1/2 Spiral Bound Notebook Cover Replacement: 10 단계, 이미지 2/2
    • Without removing the binding clip, open it and slide the cardstock onto the paper block while making sure their holes aligned.
  11. Spiral Bound Notebook Cover Replacement: 11 단계, 이미지 1/3 Spiral Bound Notebook Cover Replacement: 11 단계, 이미지 2/3 Spiral Bound Notebook Cover Replacement: 11 단계, 이미지 3/3
    • Perform Steps 1 through 4 in reverse to complete the replacement.
결론
To reassemble your device, follow instructions 1 - 4 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Abel Mbaziira
회원 가입일: 01/18/23
220 평판
안내서 1개 작성함
York University, Team O-31, Woodhouse Winter 2023 York University, Team O-31, Woodhouse Winter 2023 회원
YORK-WOODHOUSE-W23SOG31
1 회원
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 33
30일 전: 153
전체 시간: 2,154
