주요 콘텐츠로 건너뛰기
Sprinkler Head Replacement
필요한 것
  1. Sprinkler Head Replacement, Sprinkler Head: 1 단계, 이미지 1개 중 1개
    • Turn off the water supply to the sprinklers.
    • This process will vary depending on your sprinkler controller.
  2. Sprinkler Head Replacement: 2 단계, 이미지 1개 중 1개
    • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
  3. Sprinkler Head Replacement: 3 단계, 이미지 1개 중 1개
    • Dig a hole down to the base of the sprinkler head.
    • Be careful to avoid puncturing the sprinkler line.
  4. Sprinkler Head Replacement: 4 단계, 이미지 1개 중 1개
    • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
  5. Sprinkler Head Replacement: 5 단계, 이미지 2개 중 1개 Sprinkler Head Replacement: 5 단계, 이미지 2개 중 2개
    • Unscrew the sprinkler head from the line it is attached to.
    • If is loose enough you may not need pliers.
  6. Sprinkler Head Replacement: 6 단계, 이미지 2개 중 1개 Sprinkler Head Replacement: 6 단계, 이미지 2개 중 2개
    • Coat the threads of the water line with teflon tape to avoid leaking.
  7. Sprinkler Head Replacement: 7 단계, 이미지 2개 중 1개 Sprinkler Head Replacement: 7 단계, 이미지 2개 중 2개
    • Using your hand, screw the new sprinkler head on over the teflon tape.
    • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
  8. Sprinkler Head Replacement: 8 단계, 이미지 1개 중 1개
    • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
  9. Sprinkler Head Replacement: 9 단계, 이미지 1개 중 1개
    • Turn the sprinkler system on.
  10. Sprinkler Head Replacement: 10 단계, 이미지 1개 중 1개
    • Twist the top of the sprinkler until it is aimed where you want it.
  11. Sprinkler Head Replacement: 11 단계, 이미지 1개 중 1개
    • Use a flat head screwdriver to adjust the flow of water if needed.
    • Turning right decreases the water flow. Turning left increases the water flow.
결론
Enjoy your green lawn and water savings.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adam Sylvia
회원 가입일: 07/03/18
251 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 24
전체 시간: 886
