주요 콘텐츠로 건너뛰기
Sprint Sanyo RL-4920 Display Replacement
필요한 것
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: 1 단계, 이미지 1/1
    • Flip the phone over so that the screen is facing down.
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: 2 단계, 이미지 1/2 Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: 2 단계, 이미지 2/2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: 3 단계, 이미지 1/2 Sprint Sanyo RL-4920 Display Replacement, Screws: 3 단계, 이미지 2/2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: 4 단계, 이미지 1/1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: 5 단계, 이미지 1/1
    • Separate the two cases.
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: 6 단계, 이미지 1/1
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Sprint Sanyo RL-4920 Display Replacement, Display: 7 단계, 이미지 1/2 Sprint Sanyo RL-4920 Display Replacement, Display: 7 단계, 이미지 2/2
    • Locate the 4 white clips of the dispaly.
  8. Sprint Sanyo RL-4920 Display Replacement: 8 단계, 이미지 1/2 Sprint Sanyo RL-4920 Display Replacement: 8 단계, 이미지 2/2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Sprint Sanyo RL-4920 Display Replacement: 9 단계, 이미지 1/2 Sprint Sanyo RL-4920 Display Replacement: 9 단계, 이미지 2/2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Sprint Sanyo RL-4920 Display Replacement: 10 단계, 이미지 1/2 Sprint Sanyo RL-4920 Display Replacement: 10 단계, 이미지 2/2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patrick Olmstead
회원 가입일: 10/22/13
240 평판
안내서 2개 작성하였습니다
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 회원
CLEM-BENSON-F13S13G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 242
