주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
부품
지정된 부품이 없습니다.
  1. Flip the phone over so that the screen is facing down.
    • Flip the phone over so that the screen is facing down.
  2. Push the gray lever up towards the top of the phone. Pull up on the battery pack and completely separate it from the phone.
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
  3. Locate the five screws around the back casing. Use a three-prong screw bit to remove all five screws.
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
  4. Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
  5. Separate the two cases.
    • Separate the two cases.
  6. Use the plastic opening tool to remove the motherboard from the front case.
    • Use the plastic opening tool to remove the motherboard from the front case.
  7. Locate the 4 white clips of the dispaly. Locate the 4 white clips of the dispaly.
    • Locate the 4 white clips of the dispaly.
  8. Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display. Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
  9. Grasp the display on both sides and carefully pull the display off of the printed circuit board. Grasp the display on both sides and carefully pull the display off of the printed circuit board.
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
  10. Using the plastic opening tool, carefully remove the yellow film covering the display connector. Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patrick Olmstead
회원 가입일: 2013년 10월 22일
240 평판
안내서 2개 작성하였습니다
Clemson, Team 13-5, Benson Fall 2013 Clemson, Team 13-5, Benson Fall 2013 회원
CLEM-BENSON-F13S13G5
3 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 120
