이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Push the gray lever up towards the top of the phone.
Pull up on the battery pack and completely separate it from the phone.
Locate the five screws around the back casing.
Use a three-prong screw bit to remove all five screws.
Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
Use the plastic opening tool to remove the motherboard from the front case.
The plastic keys are attached to the back side of the front case. To remove the keys, pull the plastic piece out of the front case using the plastic opening tool.
다른 한 분이 해당 안내서를 완성하였습니다.
