주요 콘텐츠로 건너뛰기
Sprout Channel Cubby Speaker Replacement
필요한 것
  1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: 1 단계, 이미지 1/2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: 1 단계, 이미지 2/2
    • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
    • It is easiest to start on the corners.
  2. Sprout Channel Cubby Speaker Replacement, Speaker: 2 단계, 이미지 1/2 Sprout Channel Cubby Speaker Replacement, Speaker: 2 단계, 이미지 2/2
    • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
  3. Sprout Channel Cubby Speaker Replacement: 3 단계, 이미지 1/2 Sprout Channel Cubby Speaker Replacement: 3 단계, 이미지 2/2
    • Remove black tape.
    • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
    • Replace the speaker.
    • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
jasen biggins
회원 가입일: 08/26/15
741 평판
안내서 5개 작성하였습니다
USF Tampa, Team 14-101, Meier Fall 2015 USF Tampa, Team 14-101, Meier Fall 2015 회원
USFT-MEIER-F15S14G101
4 회원들
안내서 12개 작성하였습니다
댓글 2개
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - 답글
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 1,042
