주요 콘텐츠로 건너뛰기
Spy Gear Video Walkie Talkies Camera Replacement
필요한 것
  1. Spy Gear Video Walkie Talkies Camera Replacement, Top Cover: 1 단계, 이미지 1/1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Camera Replacement: 2 단계, 이미지 1/1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Camera Replacement: 3 단계, 이미지 1/1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Camera Replacement: 4 단계, 이미지 1/1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Camera Replacement: 5 단계, 이미지 1/1
    • Once the Top Cover is free, you will have full access to the circuitry.
  6. Spy Gear Video Walkie Talkies Camera Replacement, Camera: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use Tweezers to remove the side button.
  7. Spy Gear Video Walkie Talkies Camera Replacement: 7 단계, 이미지 1/2 Spy Gear Video Walkie Talkies Camera Replacement: 7 단계, 이미지 2/2
    • Release the zero insertion force (ZIF) connector.
    • Pull the ribbon cable away carefully.
  8. Spy Gear Video Walkie Talkies Camera Replacement: 8 단계, 이미지 1/1
    • With the ribbon cable free from obstructions, use a Prying Tool to release the circuit board from the guide studs.
  9. Spy Gear Video Walkie Talkies Camera Replacement: 9 단계, 이미지 1/1
    • With a plastic Prying Tool, separate the screen from the mounting tray.
    • Adhesive between the layers may provoke damage to the screen or tray. Take your time.
  10. Spy Gear Video Walkie Talkies Camera Replacement: 10 단계, 이미지 1/1
    • Once the screen is completely folded away from the mounting tray, release it from the circuit board by hand.
  11. Spy Gear Video Walkie Talkies Camera Replacement: 11 단계, 이미지 1/1
    • Release the back of the mounting tray using a plastic Pick to unhook the barb from the circuit board.
  12. Spy Gear Video Walkie Talkies Camera Replacement: 12 단계, 이미지 1/1
    • Now remove the mounting tray complete with camera and ribbon cable attached by sliding away from the screen.
    • You must not damage the screen or screen ribbon cable in this step.
  13. Spy Gear Video Walkie Talkies Camera Replacement: 13 단계, 이미지 1/1
    • Discard faulty camera and mounting tray.
결론
다른 2명이 해당 안내서를 완성하였습니다.
James French
회원 가입일: 02/15/16
151 평판
안내서 1개 작성함
IUPUI, Team 7-7, Wilson Spring 2016 IUPUI, Team 7-7, Wilson Spring 2016 회원
IUPUI-WILSON-S16S7G7
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 700
