주요 콘텐츠로 건너뛰기
Spy Gear Video Walkie Talkies Top Cover Replacement
필요한 것
  1. Spy Gear Video Walkie Talkies Top Cover Replacement, Top Cover: 1 단계, 이미지 1/1
    • Remove the battery cover by removing the P1 Philips screw.
    • Remove the 3 AA batteries by hand.
  2. Spy Gear Video Walkie Talkies Top Cover Replacement: 2 단계, 이미지 1/1
    • Unscrew Top Cover with a 3mm Triangle driver bit from the Driver Kit.
  3. Spy Gear Video Walkie Talkies Top Cover Replacement: 3 단계, 이미지 1/1
    • Use Opening Tool to release barbed latch on top cover.
  4. Spy Gear Video Walkie Talkies Top Cover Replacement: 4 단계, 이미지 1/1
    • Release pilot studs near the hinge with Metal Spudger.
  5. Spy Gear Video Walkie Talkies Top Cover Replacement: 5 단계, 이미지 1/1
    • Once the Top Cover is free, you will have full access to the circuitry.
결론
Adam Kinnett
회원 가입일: 02/15/16
121 평판
안내서 1개 작성함
IUPUI, Team 7-7, Wilson Spring 2016 IUPUI, Team 7-7, Wilson Spring 2016 회원
IUPUI-WILSON-S16S7G7
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 223
