주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Before we begin taking apart the device, make sure that you have visited the Troubleshooting Page in order to verify that the problem with the device is in fact a faulty microphone.
  1. Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
  2. Find the connection of the red and black wires to the circuit board behind the LED screen.
    • Find the connection of the red and black wires to the circuit board behind the LED screen.
    • Un-solder the wires from the board using the soldering iron.
    • Need Help Soldering? Check out How To Solder and Desolder Connections
  3. Find the connection of the red and black wires to the funnel-shaped lens cover.
    • Find the connection of the red and black wires to the funnel-shaped lens cover.
    • Un-solder the wires from the microphone using the soldering iron.
    • Remove the red and black wires from the device and solder on the replacement.
결론
Justin Diehl
회원 가입일: 2014년 09월 22일
58 평판
안내서 1개 작성함
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 회원
USFT-BROWN-F14S4G5
3 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 247
