주요 콘텐츠로 건너뛰기
Squier Strat Guitar Pickups Replacement
필요한 것
  1. Squier Strat Guitar Pickups Replacement, Pickups: 1 단계, 이미지 1/3 Squier Strat Guitar Pickups Replacement, Pickups: 1 단계, 이미지 2/3 Squier Strat Guitar Pickups Replacement, Pickups: 1 단계, 이미지 3/3
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: 2 단계, 이미지 1/2 Squier Strat Guitar Pickups Replacement: 2 단계, 이미지 2/2
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: 3 단계, 이미지 1/3 Squier Strat Guitar Pickups Replacement: 3 단계, 이미지 2/3 Squier Strat Guitar Pickups Replacement: 3 단계, 이미지 3/3
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: 4 단계, 이미지 1/2 Squier Strat Guitar Pickups Replacement: 4 단계, 이미지 2/2
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: 5 단계, 이미지 1/2 Squier Strat Guitar Pickups Replacement: 5 단계, 이미지 2/2
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: 6 단계, 이미지 1/2 Squier Strat Guitar Pickups Replacement: 6 단계, 이미지 2/2
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: 7 단계, 이미지 1/2 Squier Strat Guitar Pickups Replacement: 7 단계, 이미지 2/2
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ion
회원 가입일: 09/29/15
479 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 회원
CPSU-GREEN-F15S10G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 79
전체 시간: 6,848
