이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unwind the strings by turning the tuning pegs.
Pull the strings out of the tuning peg holes.
Push the strings out through the back plate holes.
Lift up the pickup guard gently.
Flip the pickup guard to expose the wiring.
Place a towel underneath the pickup guard to protect your guitar's body.
Take note of where each pickup is wired.
Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
Desolder the pickups from the potentiometers.
Flip the pickup guard back to its original position.
Remove the screws holding the pickups to the pickup guard.
Flip the pickup guard to reveal the wiring.
Remove the pickups from the pickup guard. They should come out very easily.
다른 4명이 해당 안내서를 완성하였습니다.
