소개
This guide shows you the process of doing a permanent repair for a detached or loose faucet handle. Faucet handles can become loose with excessive use or poor installation. I will show you how to make use of your handle with a fast, stable, and easy fix within 5-10 minutes.
필요한 것
Remove the sink handle, keeping in mind the orientation of the handle where it was removed—you will have to insert it back the same way.
If the screw has not fallen out and is still inside the handle, unscrew it with a Phillips screwdriver.
댓글 한 개
Thank you for sharing this guide on replacing the handle on a Stainless MOEN kitchen faucet. The step-by-step instructions and photographs were very helpful and made the process easy to understand. I was able to successfully replace the handle on my own faucet following your guide, and it's working perfectly now. I appreciate the time and effort you took to create this helpful resource.
