메인 콘텐츠로 스킵하기
소개
This guide will show you how to replace the blade on a Stanley 10-079 Box Cutter.
  1. Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
    • Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
  2. Using a screwdriver or a coin remove the single screw in the center of the box cutter
    • Using a screwdriver or a coin remove the single screw in the center of the box cutter
  3. Carefully pull up on the top half of the cutter exposing the blade on the inside.
    • Carefully pull up on the top half of the cutter exposing the blade on the inside.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. carefully without cutting yourself lift the old blade out this should require no force.
    • carefully without cutting yourself lift the old blade out this should require no force.
  6. with the old blade out replace it with a new blade from the back or one that was purchased separately.
    • with the old blade out replace it with a new blade from the back or one that was purchased separately.
  7. With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2. With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
    • With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
  8. insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
    • insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
  9. With the center screw re-installed you are all set to use your Stanley 10-079 box cutter again with a brand new blade.
    • With the center screw re-installed you are all set to use your Stanley 10-079 box cutter again with a brand new blade.
결론
You are all set and ready to use your brand new installed blade! Here are some replacement blades that I found on amazon. https://www.amazon.com/Stanley-11-921L-5...
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Cawley
회원 가입일: 2017년 10월 11일
157 평판
안내서 1개 작성함
Mikes computer and mobile device repairs Mikes computer and mobile device repairs 회원
Business
1 회원
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 41
전체 시간: 600
