주요 콘텐츠로 건너뛰기
Stanley 10-079 Box Cutter Blade Replacement
필요한 것
  1. Stanley 10-079 Box Cutter Blade  Replacement, Knife Blade: 1 단계, 이미지 1개 중 1개
    • Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
  2. Stanley 10-079 Box Cutter Blade  Replacement: 2 단계, 이미지 1개 중 1개
    • Using a screwdriver or a coin remove the single screw in the center of the box cutter
  3. Stanley 10-079 Box Cutter Blade  Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully pull up on the top half of the cutter exposing the blade on the inside.
  4. Stanley 10-079 Box Cutter Blade  Replacement: 4 단계, 이미지 1개 중 1개
    • carefully without cutting yourself lift the old blade out this should require no force.
  5. Stanley 10-079 Box Cutter Blade  Replacement: 5 단계, 이미지 1개 중 1개
    • with the old blade out replace it with a new blade from the back or one that was purchased separately.
  6. Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: 6 단계, 이미지 2개 중 1개 Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: 6 단계, 이미지 2개 중 2개
    • With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
  7. Stanley 10-079 Box Cutter Blade  Replacement, Final Assembily: 7 단계, 이미지 1개 중 1개
    • insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
  8. Stanley 10-079 Box Cutter Blade  Replacement: 8 단계, 이미지 1개 중 1개
    • With the center screw re-installed you are all set to use your Stanley 10-079 box cutter again with a brand new blade.
결론
You are all set and ready to use your brand new installed blade! Here are some replacement blades that I found on amazon. https://www.amazon.com/Stanley-11-921L-5...
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michael Cawley
회원 가입일: 10/11/17
184 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 63
전체 시간: 6,643
