주요 콘텐츠로 건너뛰기
Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: 1 단계, 이미지 1개 중 1개
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: 2 단계, 이미지 3개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 2 단계, 이미지 3개 중 2개 Stanley ST-222A-120 Pressure Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: 3 단계, 이미지 2개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 3 단계, 이미지 2개 중 2개
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: 4 단계, 이미지 2개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: 5 단계, 이미지 2개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 5 단계, 이미지 2개 중 2개
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: 6 단계, 이미지 2개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: 7 단계, 이미지 2개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 7 단계, 이미지 2개 중 2개
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: 8 단계, 이미지 3개 중 1개 Stanley ST-222A-120 Pressure Sensor Replacement: 8 단계, 이미지 3개 중 2개 Stanley ST-222A-120 Pressure Sensor Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Miles Henderson
회원 가입일: 10/07/20
243 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 34
전체 시간: 758
