소개
If your sharpener is making a loud grinding noise or the electric motor is running but the cutter is not rotating, then follow these steps to replace the gears in your Staples 34462 Electric Pencil Sharpener.
필요한 것
Using a Philips 00 screwdriver, remove the six 9.87mm screws securing the gear housing.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
