주요 콘텐츠로 건너뛰기
Starbucks Barista Ready Light Replacement
필요한 것
  1. Starbucks Barista Ready Light Replacement, Ready Light: 1 단계, 이미지 1/2 Starbucks Barista Ready Light Replacement, Ready Light: 1 단계, 이미지 2/2
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: 2 단계, 이미지 1/3 Starbucks Barista Ready Light Replacement: 2 단계, 이미지 2/3 Starbucks Barista Ready Light Replacement: 2 단계, 이미지 3/3
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: 3 단계, 이미지 1/1
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David
회원 가입일: 01/28/11
739 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 회원
CPSU-REGAN-W11S4G42
4 회원들
안내서 5개 작성하였습니다
댓글 4개
Youth and sports for
Rich Ridout - 답글
Where can I get a new LED bulb?
Paula - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 6,096
