주요 콘텐츠로 건너뛰기
Starbucks Barista Steam Wand replacement or cleaning
필요한 것
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: 1 단계, 이미지 1/1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: 2 단계, 이미지 1/2 Starbucks Barista Steam Wand replacement or cleaning: 2 단계, 이미지 2/2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
결론
다른 4명이 해당 안내서를 완성하였습니다.
David
회원 가입일: 01/28/11
748 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 회원
CPSU-REGAN-W11S4G42
4 회원들
안내서 5개 작성하였습니다
댓글 2개
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - 답글
I have a machine where the steam wand was leaking.
It just needed the cam on the steam valve to be adjusted, so that the valve could be closed, before the cam hits the stop.
Gary Naka - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 19
전체 시간: 15,943
