주요 콘텐츠로 건너뛰기
Starbucks Barista Steam Wand replacement or cleaning
필요한 것
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: 1 단계, 이미지 1/1
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: 2 단계, 이미지 1/2 Starbucks Barista Steam Wand replacement or cleaning: 2 단계, 이미지 2/2
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
결론
다른 4명이 해당 안내서를 완성하였습니다.
David
회원 가입일: 01/28/11
748 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 회원
CPSU-REGAN-W11S4G42
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 36
전체 시간: 15,882
