주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement
필요한 것
  1. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Before you begin: 1 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Before you begin: 1 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Before you begin: 1 단계, 이미지 3개 중 3개
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
  2. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    TR6 Torx Security Screwdriver
    $5.99
  3. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the back cover: 3 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the back cover: 3 단계, 이미지 2개 중 2개
    • Remove the back cover.
  4. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the battery: 4 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the battery: 4 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the battery: 4 단계, 이미지 3개 중 3개
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
  5. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the mounting bracket screws: 5 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the mounting bracket screws: 5 단계, 이미지 2개 중 2개
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
  6. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the mounting bracket: 6 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the mounting bracket: 6 단계, 이미지 2개 중 2개
  7. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Disconnect the rumble motors: 7 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Disconnect the rumble motors: 7 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Disconnect the rumble motors: 7 단계, 이미지 3개 중 3개
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
  8. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement: 8 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement: 8 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement: 8 단계, 이미지 3개 중 3개
    • Repeat to disconnect the other rumble motor.
  9. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Disconnect the interconnect cable: 9 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Disconnect the interconnect cable: 9 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Disconnect the interconnect cable: 9 단계, 이미지 3개 중 3개
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
  10. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement: 10 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
  11. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the main board screws: 11 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the main board screws: 11 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the main board screws: 11 단계, 이미지 3개 중 3개
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
  12. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the main board: 12 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the main board: 12 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the main board: 12 단계, 이미지 3개 중 3개
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
  13. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Rubber piece information: 13 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Rubber piece information: 13 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Rubber piece information: 13 단계, 이미지 3개 중 3개
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
  14. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the hinge pin: 14 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the hinge pin: 14 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the hinge pin: 14 단계, 이미지 3개 중 3개
    • With one hand, fully depress one trigger.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
  15. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the trigger: 15 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the trigger: 15 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the trigger: 15 단계, 이미지 3개 중 3개
    • Lift the trigger straight up and remove it.
    • Remove the spring and store it in a safe place for reassembly.
    • The spring will either stick to the trigger's magnet or stay on its post.
  16. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the other trigger: 16 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the other trigger: 16 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the other trigger: 16 단계, 이미지 3개 중 3개
    • Repeat to remove the other trigger.
  17. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Reassembly information: 17 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Reassembly information: 17 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Reassembly information: 17 단계, 이미지 3개 중 3개
    • During reassembly, follow this step to install the triggers.
    • Place one of the trigger springs over its post on the controller.
    • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
    • If you're having trouble, make sure you're installing the trigger on the correct side.
    • Test the trigger to ensure the pin was properly installed.
    • Repeat to install the other trigger.
  18. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the midframe screws: 18 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the midframe screws: 18 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
    • When removing the screw in the center of the controller, be careful not to slip and damage the flexible button circuit.
  19. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the midframe: 19 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the midframe: 19 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the midframe: 19 단계, 이미지 3개 중 3개
    • Lift the midframe straight up and remove it.
    • The buttons and their silicone membranes are now sitting loose in their recesses. Don't flip the front shell or the buttons will fall out. Optionally, remove the membranes and buttons and set them aside.
    • During reassembly:
    • If you removed the buttons and their membranes:
    • Make sure the rubber button dampeners (that surround the button recesses) are pushed down and fully seated against the shell.
    • Install the buttons and membranes, using the alignment tabs to orient each button in its recess. Each one is keyed for proper location and orientation.
    • Check the two large silicone button membranes to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
    • Use the alignment posts to ensure the midframe is in the right position.
  20. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Check for the Steam button membrane: 20 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Check for the Steam button membrane: 20 단계, 이미지 2개 중 2개
    • Check if the Steam button's silicone membrane stuck to the button circuit on the midframe.
    • If it did, either put the membrane back in place or set it aside.
  21. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Lay the midframe down: 21 단계, 이미지 1개 중 1개
    • Set the midframe down so the underside is facing up.
  22. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the bottom of the button circuit: 22 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the bottom of the button circuit: 22 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the bottom of the button circuit: 22 단계, 이미지 3개 중 3개
    • Starting with the right side, use your fingers to unhook the button circuit from the two tabs.
  23. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the bumper membranes: 23 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the bumper membranes: 23 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the bumper membranes: 23 단계, 이미지 3개 중 3개
    • Use your fingers to gently pull both silicone bumper membranes off the controller.
    • During reassembly, press the membranes into place until both pegs slide fully into their sockets.
  24. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the bumper buttons: 24 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the bumper buttons: 24 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the bumper buttons: 24 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to gently unhook the section of button circuit for each bumper.
  25. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Flip the midframe over: 25 단계, 이미지 1개 중 1개
    • Flip the midframe over.
  26. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the button circuit: 26 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the button circuit: 26 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Unhook the button circuit: 26 단계, 이미지 3개 중 3개
    • Six pegs and a curved strip of adhesive secure the button circuit to the midframe.
    • Unhook the button circuit from all six pegs by slowly lifting until it slides off the peg.
    • Peel up the section of button circuit with adhesive (near the action buttons) until it fully detaches.
    • If the adhesive stays stuck to the button circuit, remove and transfer it to the midframe.
    • Don't try to fully remove the button circuit yet—it's still attached by two boards near the rumble motors.
  27. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Flip the midframe over: 27 단계, 이미지 1개 중 1개
  28. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the R4 and R5 buttons: 28 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the R4 and R5 buttons: 28 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the R4 and R5 buttons: 28 단계, 이미지 3개 중 3개
    • The two white, rectangular boards near the rumble motors are secured with mild ahdesive.
    • Slide the flat end of a spudger behind the board to separate the adhesive securing it.
    • Pull the board off the midframe.
  29. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the L4 and L5 buttons: 29 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the L4 and L5 buttons: 29 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, Remove the L4 and L5 buttons: 29 단계, 이미지 3개 중 3개
    • Repeat to separate the other board.
    • During reassembly, check if your replacement button circuit has adhesive pre-installed on the boards. If it doesn't, use thin double-sided tape to secure them. Make sure the alignment pegs go through the holes in the bottom corners of the board.
  30. Steam Controller (2nd Gen, 2026) Flexible Button Circuit Replacement, You're left with the button circuit: 30 단계, 이미지 1개 중 1개
    • Remove the midframe—you're now left with the button circuit for replacement.
결론
Spencer Day
회원 가입일: 09/14/22
187,536 평판
안내서 1,187개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 75
지난 30일: 368
전체 시간: 377
