소개
Use this guide to replace the back cover on your Steam Deck LCD, or to remove it for further repairs.
Remember: follow general electrostatic discharge (ESD) safety procedures while repairing your device.
Note: The back button faces (L4, R4, L5, and R5) are part of the back cover and cannot be separately removed.
Valve warns that removing the back cover can weaken the Steam Deck's structural integrity.
필요한 것
이 단계에 사용된 도구:FixMat$36.95
Use a Phillips driver to remove the eight screws securing the back cover:
Four coarse thread 9.5 mm-long screws
Four fine thread 5.8 mm-long screws
Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
Pry up on the back cover to release it from the locking clips.
Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 5개
Alguien sabe donde puedo comprar los 4 tornillos del medio de la tapa trasera, creo que hacen 1,6x5mm ?
La tapa que venden vienen con los tornillos?
Si pueden ser los originales mejor.
Muchas gracias.
one of my screws stripped what should I do?
Can I use it on OLED steamdeck?
Is this backplate also compatible with the OLED model?
For everyone wondering: it is compatible with the OLED model! I just replaced my backplate with this one and it fits perfectly! :)
