주요 콘텐츠로 건너뛰기
Steam Deck OLED Right Button Board Replacement
필요한 것
  1. Steam Deck OLED Right Button Board Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 3개
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Right Button Board Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 1개 Steam Deck OLED Right Button Board Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Right Button Board Replacement, Unclip a handle: 3 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Unclip a handle: 3 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Unclip a handle: 3 단계, 이미지 3개 중 3개
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Right Button Board Replacement, Unclip the top and bottom edges: 4 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Unclip the top and bottom edges: 4 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Unclip the top and bottom edges: 4 단계, 이미지 3개 중 3개
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Right Button Board Replacement, Remove the back cover: 5 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Remove the back cover: 5 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Remove the back cover: 5 단계, 이미지 3개 중 3개
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED Right Button Board Replacement, Disconnect the battery: 6 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the battery: 6 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the battery: 6 단계, 이미지 3개 중 3개
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
  7. Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 7 단계, 이미지 2개 중 1개 Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 7 단계, 이미지 2개 중 2개
    • During disassembly, skip the next three steps.
    • During reassembly:
    • Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
    • Reconnect the interconnect cable ZIF connector.
  8. Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 8 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 8 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 8 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
  9. Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 9 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 9 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Reassembly instructions: 9 단계, 이미지 3개 중 3개
    • During reassembly, follow this step and the above three steps to reconnect the battery.
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
    • Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
    • Be careful not to crease or strain the cable.
  10. Steam Deck OLED Right Button Board Replacement, Disconnect the right thumbstick: 10 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the right thumbstick: 10 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the right thumbstick: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the point of a spudger to flip up the small locking flap on the right thumbstick ZIF connector.
    • The pull tab on this connector may be labeled TS.
    • Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
  11. Steam Deck OLED Right Button Board Replacement, Disconnect the interconnect cable: 11 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the interconnect cable: 11 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the interconnect cable: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑R.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
    • During reassembly, don't reconnect this cable yet. You'll reconnect it later.
  12. Steam Deck OLED Right Button Board Replacement, Disconnect the right thumbstick: 12 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the right thumbstick: 12 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the right thumbstick: 12 단계, 이미지 3개 중 3개
    • Flip up the small black locking flap on the right thumbstick cable ZIF connector.
    • The pull tabs on the remaining ZIF connectors in this procedure may be labeled DB.
    • Slide the connector straight out of its socket to disconnect it.
  13. Steam Deck OLED Right Button Board Replacement, Disconnect the right button board: 13 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the right button board: 13 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the right button board: 13 단계, 이미지 3개 중 3개
    • Flip up the small locking flap on the button board cable ZIF connector, located in the bottom left corner.
  14. Steam Deck OLED Right Button Board Replacement, Disconnect the remaining ZIF connectors: 14 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the remaining ZIF connectors: 14 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the remaining ZIF connectors: 14 단계, 이미지 3개 중 3개
    • Repeat the ZIF cable disconnection procedure for the remaining three ZIF connectors:
    • The touchpad cable
    • The touchpad board cable
    • You may need to lift this cable as you pull to free its arms.
    • The action buttons and menu button cable
  15. Steam Deck OLED Right Button Board Replacement, Disconnect the right haptics: 15 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Disconnect the right haptics: 15 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Disconnect the right haptics: 15 단계, 이미지 3개 중 3개
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the left side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector, and not on the cables or socket.
    • Insert the point of your spudger under the neck of the haptics cable connector.
    • Gently pry up to disconnect it.
  16. Steam Deck OLED Right Button Board Replacement, Remove the right button board screws: 16 단계, 이미지 1개 중 1개
    • Use your T6 Torx driver to remove the four screws securing the right button board:
    • Two 5.9 mm‑long screws
    • One 3.8 mm‑long screw
    • One 4.9 mm‑long screw
  17. Steam Deck OLED Right Button Board Replacement, Remove the right button board: 17 단계, 이미지 3개 중 1개 Steam Deck OLED Right Button Board Replacement, Remove the right button board: 17 단계, 이미지 3개 중 2개 Steam Deck OLED Right Button Board Replacement, Remove the right button board: 17 단계, 이미지 3개 중 3개
    • Insert the point of your spudger between the bottom left corner of the button board and the frame.
    • Pry up until you can grab the button board with your fingers.
    • Remove the button board.
    • During reassembly, make sure none of the six cables become trapped underneath the button board as you lay it into place.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
95,395 평판
안내서 465개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
2가이드 댓글
where it's possible to buy the board for replacement?
Andrea Grosso - 답글
where it's possible to buy the board?
AntiBioTikka 2.0 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 125
전체 시간: 1,893
