주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Steam Deck Right Thumbstick Replacement
필요한 것
동영상 개요
  1. Steam Deck Right Thumbstick Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 1개 Steam Deck Right Thumbstick Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 2개 Steam Deck Right Thumbstick Replacement, Prepare your Steam Deck for disassembly: 1 단계, 이미지 3개 중 3개
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down into its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck Right Thumbstick Replacement, Remove the back cover screws: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Phillips driver to remove the eight screws securing the back cover:
    • Four coarse thread 9.5 mm-long screws
    • Four fine thread 5.8 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the snuggest into the screw head.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your Steam Deck.
  3. Steam Deck Right Thumbstick Replacement, Unclip the back cover: 3 단계, 이미지 2개 중 1개 Steam Deck Right Thumbstick Replacement, Unclip the back cover: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick into the thin gap between the back cover and the front shell, along the edge of the right grip.
    • If you're having trouble inserting your pick at the grip seam, try starting at either the top or bottom long edges first, then slide the pick towards the grip.
    • Pry up on the back cover to release it from the locking clips.
  4. Steam Deck Right Thumbstick Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Steam Deck Right Thumbstick Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Steam Deck Right Thumbstick Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Once the clips are disconnected from one edge, the rest disconnect easily.
    • Grip the back cover at the opening you just created and pull it up and away from the device to unclip the long edges.
    • Remove the back cover.
  5. Steam Deck Right Thumbstick Replacement, Uncover the hidden shield screw: 5 단계, 이미지 2개 중 1개 Steam Deck Right Thumbstick Replacement, Uncover the hidden shield screw: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • If you have a refreshed Steam Deck version with the black motherboard cover, skip this step.
    • Use a pair of tweezers to remove the piece of foil tape covering the hidden screw on the board shield.
    • If possible, try not to rip or tear this tape so it can be reused. If necessary, you can fashion a replacement by cutting a piece of aluminum foil tape to fit.
  6. Steam Deck Right Thumbstick Replacement, Remove the shield screws: 6 단계, 이미지 2개 중 1개 Steam Deck Right Thumbstick Replacement, Remove the shield screws: 6 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the three screws securing the board shield:
    • One 3.4 mm screw
    • Two 3.7 mm screws
    • Only the two 3.7 mm screws along the left edge are present in refreshed Steam Decks.
  7. Steam Deck Right Thumbstick Replacement, Remove the shield: 7 단계, 이미지 3개 중 1개 Steam Deck Right Thumbstick Replacement, Remove the shield: 7 단계, 이미지 3개 중 2개 Steam Deck Right Thumbstick Replacement, Remove the shield: 7 단계, 이미지 3개 중 3개
    • Remove the board shield.
    • Depending on the age of your Steam Deck, this shield may stick to the thermal pads underneath.
    • During reassembly, ensure that the fan cable lays on the side of the board shield and isn't pinched underneath.
  8. Steam Deck Right Thumbstick Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Steam Deck Right Thumbstick Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Steam Deck Right Thumbstick Replacement, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    • Grip the battery cable by its pull tab and pull it directly away from the motherboard to disconnect it.
    • Alternatively, use the flat end of a spudger or a clean fingernail to gently push the connector out of its socket, then disconnect it completely by hand.
  9. Steam Deck Right Thumbstick Replacement, Disconnect the right thumbstick cable: 9 단계, 이미지 3개 중 1개 Steam Deck Right Thumbstick Replacement, Disconnect the right thumbstick cable: 9 단계, 이미지 3개 중 2개 Steam Deck Right Thumbstick Replacement, Disconnect the right thumbstick cable: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The right thumbstick will be on your left-hand side when working on the Steam Deck, as it's laying upside down.
    • Use the pointed end of a spudger to lift up the small locking flap on the thumbstick cable's ZIF connector.
    • Use a pair of tweezers to slide the cable out of its connector.
    • Grip the cable by the blue pull tab, not by the cable itself.
  10. Steam Deck Right Thumbstick Replacement, Remove the thumbstick screws: 10 단계, 이미지 2개 중 1개 Steam Deck Right Thumbstick Replacement, Remove the thumbstick screws: 10 단계, 이미지 2개 중 2개
    • Use a Phillips driver to remove the three 5.2 mm screws securing the thumbstick.
    • During reassembly, you may need to hold the Steam Deck off of the work surface so it isn't resting on the new thumbstick while you tighten down the screws.
  11. Steam Deck Right Thumbstick Replacement, Remove the thumbstick: 11 단계, 이미지 2개 중 1개 Steam Deck Right Thumbstick Replacement, Remove the thumbstick: 11 단계, 이미지 2개 중 2개
    • Remove the right thumbstick.
    • Replacement thumbsticks require calibration to work as expected. To calibrate new thumbsticks, follow this calibration guide.
    • Each Steam Deck ships with one of two different models of thumbsticks, Type A or Type B. Although nearly identical, capacitive touch capability relies on the correct type to be installed.
    • To identify which replacement thumbsticks you need, navigate to SettingsSystem and check the Steam Deck Controller ID.
    • If the Controller ID starts with "MEDA" that device needs Type A thumbsticks.
    • If the Controller ID starts with "MHDA" that device needs Type B thumbsticks.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
164,970 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,804개를 작성함
5가이드 댓글
Does this apply to the OLED model as well?
lhflannery - 답글 공유
The OLED model's right thumbstick guide can be found here.
Carsten Frauenheim - 답글 공유
I followed this guide and my joystick seems to be fine accept the gyro activation doesn't seem to be working for the new stick. Is there something I should specifically lookout for with the touch support to be seated properly?
Smokey D - 답글 공유
Type A right joystick has been out of stock for a while, is it coming back soon?
Iain Mackay - 답글 공유
We're working to get more in stock — check back soon!
댓글 쓰기
조회 통계:
지난 24시간: 41
지난 7일: 321
지난 30일: 1,440
전체 시간: 78,205
