주요 콘텐츠로 건너뛰기
Steam Link Disassembly
필요한 것
  1. Steam Link Disassembly, Starting up: 1 단계, 이미지 1/2 Steam Link Disassembly, Starting up: 1 단계, 이미지 2/2
    • Start by unplugging your device
    • Power cord
    • Ethernet
    • HDMI
  2. Steam Link Disassembly, Removing the rubber bottom: 2 단계, 이미지 1/2 Steam Link Disassembly, Removing the rubber bottom: 2 단계, 이미지 2/2
    • Start by removing the rubber bottom using the Guitar Pick or the Jimmy
    • The first time, the adhesive may be difficult to remove
  3. Steam Link Disassembly, Removing the screws: 3 단계, 이미지 1/2 Steam Link Disassembly, Removing the screws: 3 단계, 이미지 2/2
    • Remove the screws using a Torxx 6 bit
  4. Steam Link Disassembly, Opening the lid: 4 단계, 이미지 1/2 Steam Link Disassembly, Opening the lid: 4 단계, 이미지 2/2
    • Open-up the bottom lid using guitar pics
    • The first time you open it, it might be difficult to open. Start by reaching the rounded, bottom-right corner
  5. Steam Link Disassembly, Main board inspection: 5 단계, 이미지 1/2 Steam Link Disassembly, Main board inspection: 5 단계, 이미지 2/2
    • Marvel ArmV7 CPU
    • Vivante GC1000 GPU
결론
To reassemble your device, follow the steps in the opposite order
다른 8명이 해당 안내서를 완성하였습니다.
Jorys Paulin (Jorys_Paulin)
회원 가입일: 08/21/17
398 평판
안내서 1개 작성함
댓글 4개
bonjour esque cette carte peu servire comme raspberry merci
thesmoking gta - 답글
Non, seule une image signée par Valve peut être lancée. Elle a un accès SSH comme indiqué sur la page du SDK cependant. Notez qu'elle n'est plus fabriquée depuis décembre, donc elle n'est plus vraiment disponible.
Jorys Paulin (Jorys_Paulin) -
Somewhat unworthy Teardown. Naming the CPU brand wrong and not giving any relevant information like schematics or ICs used. THIS is by far better: https://www.allaboutcircuits.com/news/te...
EDIT: Oh, it is a community post, sry. But more information would be nice. E.g. where is the massive heat sink? There are lots of parts missing.
Jan Seewald - 답글
Hello, this is my first (and only) teardown. I made it just for fun, really. I opened my Steam Link once and then decided to put it on the internet, because I found they weren’t that much photos of it around.
The heat sink is a large piece of aluminum, and now I realize I forgot to add it, my mistake.
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 69
전체 시간: 4,763
