주요 콘텐츠로 건너뛰기
SteelSeries Arctis Pro Headset Volume Control Wheel Replacement
필요한 것
  1. SteelSeries Arctis Pro Headset Volume Control Wheel Replacement, Headset Volume Control Wheel: 1 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Headset Volume Control Wheel Replacement, Headset Volume Control Wheel: 1 단계, 이미지 2개 중 2개
    • Remove the ear cushion on the left ear muff
    • This is done by pulling slightly on the outside of the cushion and moving around it until it comes off
  2. SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 2 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the three 5mm screws with the Phillips #0 screwdriver head.
    • Separate the driver assembly from the rest of the housing
  3. SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 3 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 3 phillips #0 screws
    • Remove the circuit board by pushing the volume wheel in towards the center of the housing and pulling the board towards yourself
  4. SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 4 단계, 이미지 3개 중 1개 SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 4 단계, 이미지 3개 중 2개 SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the phillips #0 screw in the center of the headset volume wheel
    • Remove the wheel by pulling it upwards until it comes free
  5. SteelSeries Arctis Pro Headset Volume Control Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • De-solder the five points on the back of the scroll wheel
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matthew Hockey
회원 가입일: 09/16/22
558 평판
안내서 4개를 작성함
3가이드 댓글
thanks for the tutorial
I have the equipment and skills to do this repair, but need to source parts.
Where would I get a replacement wheel and what would be the part #?
My wheel is starting to fail and as I adjust it, one earpiece cuts in and out. There is also a scratching/static sound as I turn the wheel
gloptum - 답글
I am also searching for parts, Did you ever find some?
Michael McNamara -
A potential replacement is this part from digikey. I used it to fix my broken ChatMix wheel here: SteelSeries Arctis 7 2019 Edition Wireless CharMix Dial Potentiometer Replacement
Alec Probst - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 32
지난 30일: 150
전체 시간: 4,444
