소개
If the volume scroll wheel is not adjusting the volume or rotating as it should be, follow this guide to replace the wheel.
Caution: Ensure hands are dry. Moisture could mess up the wiring. Be gentle and remove necessary pieces carefully to not break the device.
필요한 것
Remove the ear cushion on the left ear muff
This is done by pulling slightly on the outside of the cushion and moving around it until it comes off
댓글 한 개
thanks for the tutorial
I have the equipment and skills to do this repair, but need to source parts.
Where would I get a replacement wheel and what would be the part #?
My wheel is starting to fail and as I adjust it, one earpiece cuts in and out. There is also a scratching/static sound as I turn the wheel
