주요 콘텐츠로 건너뛰기
SteelSeries Arctis Pro Microphone Cable Replacement
필요한 것
  1. SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: 1 단계, 이미지 1/2 SteelSeries Arctis Pro Microphone Cable Replacement, Microphone Cable: 1 단계, 이미지 2/2
    • Remove ear cushion by pulling the cushion up and towards yourself.
    • Repeat this motion around the cushion until it comes free.
  2. SteelSeries Arctis Pro Microphone Cable Replacement: 2 단계, 이미지 1/2 SteelSeries Arctis Pro Microphone Cable Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the 3 case screws.
    • Lift the driver assembly away from the rest of the housing.
  3. SteelSeries Arctis Pro Microphone Cable Replacement: 3 단계, 이미지 1/3 SteelSeries Arctis Pro Microphone Cable Replacement: 3 단계, 이미지 2/3 SteelSeries Arctis Pro Microphone Cable Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws.
    • Push the headset volume dial in-words towards the housing while simultaneously pulling the board towards yourself.
  4. SteelSeries Arctis Pro Microphone Cable Replacement: 4 단계, 이미지 1/1
    • De-solder the six connections on the side of the main board.
  5. SteelSeries Arctis Pro Microphone Cable Replacement: 5 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws that secure the microphone holder.
  6. SteelSeries Arctis Pro Microphone Cable Replacement: 6 단계, 이미지 1/3 SteelSeries Arctis Pro Microphone Cable Replacement: 6 단계, 이미지 2/3 SteelSeries Arctis Pro Microphone Cable Replacement: 6 단계, 이미지 3/3
    • Pull the microphone assembly and cable out of the housing and out towards you until it comes free.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Hockey
회원 가입일: 09/16/22
516 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 67
전체 시간: 1,147
