주요 콘텐츠로 건너뛰기
SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement
필요한 것
  1. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Ear Cushions: 1 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Ear Cushions: 1 단계, 이미지 2개 중 2개
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
  2. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Circuit Board: 2 단계, 이미지 1개 중 1개
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
  3. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
  6. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Mute Button Cap: 6 단계, 이미지 2개 중 1개 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Cap Replacement, Headset Mute Button Cap: 6 단계, 이미지 2개 중 2개
    • Flip the circuit board over and remove the keycap by pulling on it.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kyle Chang
회원 가입일: 01/24/19
1,170 평판
안내서 7개를 작성함
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 회원
CPSU-WHITE-W19S18G1
4 회원들
안내서 22개를 작성함
2가이드 댓글
Can you provide a part number or link to order the replacement mute button cap?
Pete - 답글
Did you find the part number?
Robby -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 67
전체 시간: 8,106
