주요 콘텐츠로 건너뛰기
SteelSeries Nimbus+ Mainboard Replacement
필요한 것
  1. SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: 1 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Remove the phone mount: 1 단계, 이미지 2개 중 2개
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Mainboard Replacement, Remove the sticker: 2 단계, 이미지 1개 중 1개
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the back cover: 3 단계, 이미지 1개 중 1개
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 4 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 4 단계, 이미지 2개 중 2개
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 5 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 5 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 7 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Release the plastic clips: 7 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Mainboard Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 3개
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Mainboard Replacement, Remove the back cover assembly: 10 단계, 이미지 1개 중 1개
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the board: 11 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: 12 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: 12 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Mainboard Replacement, Disconnect the thumbstick board: 12 단계, 이미지 3개 중 3개
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Mainboard Replacement, Remove the board: 13 단계, 이미지 1개 중 1개
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the mainboard: 14 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: 15 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: 15 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Mainboard Replacement, Lift up the mainboard: 15 단계, 이미지 3개 중 3개
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Mainboard Replacement, Unscrew the triggers: 16 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: 17 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Release the right trigger: 17 단계, 이미지 2개 중 2개
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: 18 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Mainboard Replacement, Release the left trigger: 18 단계, 이미지 2개 중 2개
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  19. SteelSeries Nimbus+ Mainboard Replacement, Remove the mainboard: 19 단계, 이미지 1개 중 1개
    • Compare your new mainboard with the original mainboard. It may be necessary to transfer over some components. For this, you may have to unsolder the trigger buttons or attach the rubber covers to the new mainboard.
결론
Adriana Zwink
회원 가입일: 12/18/19
62,346 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,725개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 19
전체 시간: 356
