주요 콘텐츠로 건너뛰기
SteelSeries Nimbus+ Triggers Replacement
필요한 것
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: 1 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: 1 단계, 이미지 2개 중 2개
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: 2 단계, 이미지 1개 중 1개
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: 3 단계, 이미지 1개 중 1개
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 4 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 4 단계, 이미지 2개 중 2개
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 5 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 5 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 2개
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 7 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: 7 단계, 이미지 2개 중 2개
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: 8 단계, 이미지 3개 중 3개
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: 10 단계, 이미지 1개 중 1개
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: 11 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 12 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 12 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: 12 단계, 이미지 3개 중 3개
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: 13 단계, 이미지 1개 중 1개
    • Remove the board with the thumbsticks from the mainboard.
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: 14 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 15 단계, 이미지 3개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 15 단계, 이미지 3개 중 2개 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: 15 단계, 이미지 3개 중 3개
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: 16 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: 17 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: 17 단계, 이미지 2개 중 2개
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: 18 단계, 이미지 2개 중 1개 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: 18 단계, 이미지 2개 중 2개
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
결론
Adriana Zwink
회원 가입일: 12/18/19
62,376 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,735개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 11
전체 시간: 427
