이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Hello this guide is to be used for sticking keys on a saxophone; however, this guide should be used as a last resort if cleaning the pad on the key did not solve the problem. Most sticking keys can be solved easily by simply cleaning the pad, but in extreme cases it may be deemed necessary to loosen the key itself.
필요한 것
Loosen screw until key moves freely or as desired. Once as desired, you are then ready to play the instrument and test out key!
댓글 한 개
An Issue I have with a sticky key on my Alto Saxophpone. I found a remedy on ifixit.com, a hack recommended for fixing pretty much anything! Try it out!!
kwiggins01 - 답글
