주요 콘텐츠로 건너뛰기
Stihl O25 Chain Replacement
필요한 것
  1. Stihl O25 Chain Replacement, Stihl O25 Chain: 1 단계, 이미지 1개 중 1개
    • Be sure to turn off the chainsaw before servicing it.
    • Caution: Chainsaw blades are sharp. Wear protective gloves through the procedure.
    • Loosen the nuts on the chain cover with the wrench side of the scrench until the cover comes off of the saw.
  2. Stihl O25 Chain Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the chain and chainsaw bar off of the power head.
    • Pull the chain back to loosen off of the gears, and lift straight up.
  3. Stihl O25 Chain Replacement: 3 단계, 이미지 1개 중 1개
    • Clean out the grooves on the chainsaw bar. This will help with the next step.
  4. Stihl O25 Chain Replacement: 4 단계, 이미지 1개 중 1개
    • Make sure the chain is positioned correctly. If you are looking at the top of the saw, the chain rotates away from the operator.
    • Position the chain so the teeth face away on the top of the saw.
  5. Stihl O25 Chain Replacement: 5 단계, 이미지 1개 중 1개
    • Place the bar and chain back onto the saw.
    • The bolt slot on the bar will slide onto the bolts on the saw.
    • The chain will go around the gear towards the back of the saw.
    • You may have to move the chain around to get it to fit properly.
  6. Stihl O25 Chain Replacement: 6 단계, 이미지 2개 중 1개 Stihl O25 Chain Replacement: 6 단계, 이미지 2개 중 2개
    • Tighten the chain by turning the tightening screw.
    • Insert the screwdriver end of the scrench into the screw and turn clockwise.
  7. Stihl O25 Chain Replacement: 7 단계, 이미지 1개 중 1개
    • Chain tightness is often a preference of the chainsaw operator, but a good rule of thumb to follow is when you pull up on the chain, two chain links should come out of the bar grooves.
  8. Stihl O25 Chain Replacement: 8 단계, 이미지 1개 중 1개
    • Put the cover back on and tighten the nuts down.
  9. Stihl O25 Chain Replacement: 9 단계, 이미지 1개 중 1개
    • To sharpen the chain, mark one of the teeth with a pencil or sharpie.
  10. Stihl O25 Chain Replacement: 10 단계, 이미지 1개 중 1개
    • Take a round file and place it on the cutting surface.
  11. Stihl O25 Chain Replacement: 11 단계, 이미지 1개 중 1개
    • The file should be angled slighty upwards and follow the angle of the saw tooth.
    • Slide the file while applying pressure and twist slightly.
    • Teeth on a saw alternate which way they are facing.
    • Skip one tooth to continue to sharpen on the same side. Use the same number of file strokes on each tooth.
    • Continue to sharpen until you reach the original tooth that was marked. You can then sharpen the set of teeth facing the other way with the same process.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan Comar
회원 가입일: 03/30/16
182 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 45
전체 시간: 2,013
