주요 콘텐츠로 건너뛰기
Stuck Shutter Fix Replacement
  1. Stuck Shutter Fix  Replacement, Shutter: 1 단계, 이미지 1/1
    • Put the camera in any mode other than Auto, and turn off the flash.
    • Turn off the LCD screen and press the DISP or DISPLAY button.
  2. Stuck Shutter Fix  Replacement, Adjust the Camera Setting: 2 단계, 이미지 1/1
    • For many canon cameras this will be shutter priority mode, that will give you the longest exposure time without flash.
  3. Stuck Shutter Fix  Replacement, Open/Close the Battery Door: 3 단계, 이미지 1/1
    • After a few seconds open the battery door then close it again. This will momentarily interrupt power during the exposure time.
    • Repeat the procedure until the shutter becomes unstuck.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marina Bayardo
회원 가입일: 10/22/15
233 평판
안내서 2개 작성하였습니다
University of Memphis, Team 3-2, Kim Fall 2015 University of Memphis, Team 3-2, Kim Fall 2015 회원
UM-KIM-F15S3G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 22
30일 전: 100
전체 시간: 6,943
