주요 콘텐츠로 건너뛰기
Stuffed Animal Safety Eye Replacement
필요한 것
  1. Stuffed Animal Safety Eye Replacement, Safety Eye: 1 단계, 이미지 1개 중 1개
    • Be sure to keep the eye that fell out and the backing or buy a new one.
    • New safety eyes are pretty inexpensive and easy to find.
    • Do not put the backing on the eye until it's in place.
  2. Stuffed Animal Safety Eye Replacement: 2 단계, 이미지 1개 중 1개
    • The eyes on the face are located in or close to a seam that holds it in place.
    • Use your scissors to open the seam. Be very careful to cut the thread and not the fabric.
    • Make the opening of the seam so it fits the replacement eye.
  3. Stuffed Animal Safety Eye Replacement: 3 단계, 이미지 1개 중 1개
    • Use this new hole to put the eye back in its original position.
  4. Stuffed Animal Safety Eye Replacement: 4 단계, 이미지 2개 중 1개 Stuffed Animal Safety Eye Replacement: 4 단계, 이미지 2개 중 2개
    • Insert the safety eye in the original position.
    • Before putting on the backing make sure it's symmetrical to the other eye.
  5. Stuffed Animal Safety Eye Replacement: 5 단계, 이미지 3개 중 1개 Stuffed Animal Safety Eye Replacement: 5 단계, 이미지 3개 중 2개 Stuffed Animal Safety Eye Replacement: 5 단계, 이미지 3개 중 3개
    • When the eye is in place put the backer on the eye from the inside of the plushie.
    • Use the hole of the seam we opened to do that.
    • Press very hard until the eye and the back click together.
  6. Stuffed Animal Safety Eye Replacement: 6 단계, 이미지 1개 중 1개
    • Sew the seam back up using a simple stitch.
    • Begin the stitches from the inside out so they are not visible, then fasten off the thread at the end of the seam.
    • The thread should be the same color as your plushie.
  7. Stuffed Animal Safety Eye Replacement: 7 단계, 이미지 1개 중 1개
    • Take a pin and poke at the fur carefully to make it fluffy again.
    • Doing this will ensure the eye doesn't look like it's popping out.
  8. Stuffed Animal Safety Eye Replacement: 8 단계, 이미지 1개 중 1개
    • Repeat the previous step all around the eye until it looks seamless.
    • And your done!
결론
To reassemble your device, follow these instructions in the order suggested.
작성자
1다른 기여자 명과 함께
Alana Gierbolini
회원 가입일: 03/18/22
157 평판
안내서 1개를 작성함
1가이드 댓글
This is really useful. Thank you for your contribution!
Yilin Chen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 84
전체 시간: 3,860
