주요 콘텐츠로 건너뛰기
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: 1 단계, 이미지 1/2 Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: 1 단계, 이미지 2/2
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: 2 단계, 이미지 1/2 Summer 3D Lite Convenience Stroller Back Wheel Replacement: 2 단계, 이미지 2/2
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: 3 단계, 이미지 1/1
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: 4 단계, 이미지 1/1
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Nick Taylor
회원 가입일: 09/28/15
188 평판
안내서 1개 작성함
Cal Poly, Team 11-5, Forte Fall 2015 Cal Poly, Team 11-5, Forte Fall 2015 회원
CPSU-FORTE-F15S11G5
4 회원들
안내서 3개 작성하였습니다
댓글 2개
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - 답글
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 75
전체 시간: 10,875
