주요 콘텐츠로 건너뛰기
Summer 3D Lite Convenience Stroller Front Wheel Replacement
필요한 것
  1. Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: 1 단계, 이미지 2개 중 1개 Summer 3D Lite Convenience Stroller Front Wheel Replacement, Front Wheel: 1 단계, 이미지 2개 중 2개
    • Locate the black plastic tabs on the front wheel. There should be two, opposite sides from each other.
  2. Summer 3D Lite Convenience Stroller Front Wheel Replacement: 2 단계, 이미지 2개 중 1개 Summer 3D Lite Convenience Stroller Front Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Firmly press both tabs inwards, and use your other hand to pull the wheel off
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Haugland
회원 가입일: 09/28/15
332 평판
안내서 1개를 작성함
Cal Poly, Team 11-5, Forte Fall 2015 Cal Poly, Team 11-5, Forte Fall 2015 회원
CPSU-FORTE-F15S11G5
4 회원들
안내서 4개를 작성함
16가이드 댓글
How can i order the front wheels
Amalia Ontiveros - 답글
Hi, you can contact the Summer Infant Consumer Relations Team by calling 800-268-6237, Monday-Thursday, 8:00am-6:00pm EST and Friday 8am-3pm EST.
Stroller Guy -
I think there should be a video tutorial for this product. thank you!!
Lisa D. Richards - 답글
Yes i think there should be a video
yummy mummy fantom XXX -
The Front wheel is less bending in the axis, how to make straight by hand
Samson Wong - 답글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 47
지난 30일: 311
전체 시간: 61,059
