주요 콘텐츠로 건너뛰기
Summer LookOut Duo Camera Lens Replacement
필요한 것
  1. Summer LookOut Duo Camera Lens Replacement, Camera Lens: 1 단계, 이미지 2개 중 1개 Summer LookOut Duo Camera Lens Replacement, Camera Lens: 1 단계, 이미지 2개 중 2개
    • Remove the plastic wall mount attached to the base of the stand.
    • Remove the four 9 mm screws on the back four corners of the camera using a Phillips #00 screwdriver.
    • If needed, gently bend the antenna of the camera towards you to access the screw in the bottom left corner.
  2. Summer LookOut Duo Camera Lens Replacement: 2 단계, 이미지 3개 중 1개 Summer LookOut Duo Camera Lens Replacement: 2 단계, 이미지 3개 중 2개 Summer LookOut Duo Camera Lens Replacement: 2 단계, 이미지 3개 중 3개
    • Gently remove the front casing.
    • The motherboard will go with the front casing, so don't pull too hard or else the wires connected to the speaker might break.
    • The back of the motherboard should already be facing up.
    • Remove the two 5 mm screws near the upper center on the back of the motherboard using a Phillips #00 screwdriver.
    • The old camera lens will fall off after the screws are removed.
    • Replace the new lens.
결론
작성자
3다른 기여자 명과 함께
Jordyn Looney
회원 가입일: 02/25/25
425 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 77
