주요 콘텐츠로 건너뛰기
Summer LookOut Duo Camera Stand Replacement
필요한 것
  1. Summer LookOut Duo Camera Stand Replacement, Camera Stand: 1 단계, 이미지 2개 중 1개 Summer LookOut Duo Camera Stand Replacement, Camera Stand: 1 단계, 이미지 2개 중 2개
    • Remove the plastic wall mount attached to the base of the stand.
    • Remove the four 9 mm screws on the back four corners of the camera using a Phillips #00 screwdriver.
    • If needed, gently bend the antenna of the camera out of the way to access the screw in the bottom left corner.
    • Remove the two 8 mm screws near the bottom center of the back of the camera using a Phillips #00 screwdriver.
  2. Summer LookOut Duo Camera Stand Replacement: 2 단계, 이미지 3개 중 1개 Summer LookOut Duo Camera Stand Replacement: 2 단계, 이미지 3개 중 2개 Summer LookOut Duo Camera Stand Replacement: 2 단계, 이미지 3개 중 3개
    • Gently remove the front casing.
    • The motherboard will go with the front casing, so don't pull too hard or else the wires connected to the speaker might break.
    • Grab the base of the stand and rotate it 90 degrees so the head of the stand is perpendicular to the opening. Tilt the head down and pull it through the opening.
    • Replace the new stand.
결론
작성자
3다른 기여자 명과 함께
Jordyn Looney
회원 가입일: 02/25/25
425 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 63
