주요 콘텐츠로 건너뛰기
Summer LookOut Duo Motherboard and Display Replacement
필요한 것
  1. Summer LookOut Duo Motherboard and Display Replacement, Battery: 1 단계, 이미지 3개 중 1개 Summer LookOut Duo Motherboard and Display Replacement, Battery: 1 단계, 이미지 3개 중 2개 Summer LookOut Duo Motherboard and Display Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the device over so the back is facing up.
    • Remove the 9 mm screw using a Phillips #1 screwdriver.
    • Lift the battery panel away from the device.
  2. Summer LookOut Duo Motherboard and Display Replacement: 2 단계, 이미지 3개 중 1개 Summer LookOut Duo Motherboard and Display Replacement: 2 단계, 이미지 3개 중 2개 Summer LookOut Duo Motherboard and Display Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the handheld monitor over and let the battery fall out into your hand.
    • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
    • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
    • Remove the battery from the device.
  3. Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: 3 단계, 이미지 3개 중 1개 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: 3 단계, 이미지 3개 중 2개 Summer LookOut Duo Motherboard and Display Replacement, Motherboard and Display: 3 단계, 이미지 3개 중 3개
    • Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
    • Remove the casing from the back of the handheld monitor.
    • A nylon spudger may be helpful to pry the case open.
    • Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
    • The power button may come loose as the case is being removed.
  4. Summer LookOut Duo Motherboard and Display Replacement: 4 단계, 이미지 2개 중 1개 Summer LookOut Duo Motherboard and Display Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the motherboard and monitor display together and set aside.
결론
작성자
4다른 기여자 명과 함께
Adrianna Piedra
회원 가입일: 02/25/25
85 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 88
