주요 콘텐츠로 건너뛰기
Summer LookOut Duo Navigation Buttons Replacement
필요한 것
  1. Summer LookOut Duo Navigation Buttons Replacement, Battery: 1 단계, 이미지 3개 중 1개 Summer LookOut Duo Navigation Buttons Replacement, Battery: 1 단계, 이미지 3개 중 2개 Summer LookOut Duo Navigation Buttons Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Flip the device over so the back is facing up.
    • Remove the 9 mm screw using a Phillips #1 screwdriver.
    • Lift the battery panel away from the device.
  2. Summer LookOut Duo Navigation Buttons Replacement: 2 단계, 이미지 3개 중 1개 Summer LookOut Duo Navigation Buttons Replacement: 2 단계, 이미지 3개 중 2개 Summer LookOut Duo Navigation Buttons Replacement: 2 단계, 이미지 3개 중 3개
    • Flip the handheld monitor over and let the battery fall out into your hand.
    • Using angled tweezers, gently remove the plastic wire coupling from the side of the open battery compartment.
    • If the coupling struggles to release, with a loose but firm grip, slightly wiggle the plastic wire coupling back and forth until it releases.
    • Remove the battery from the device.
  3. Summer LookOut Duo Navigation Buttons Replacement, Motherboard and Display: 3 단계, 이미지 3개 중 1개 Summer LookOut Duo Navigation Buttons Replacement, Motherboard and Display: 3 단계, 이미지 3개 중 2개 Summer LookOut Duo Navigation Buttons Replacement, Motherboard and Display: 3 단계, 이미지 3개 중 3개
    • Using the Phillips #00 screwdriver, remove the four 7mm screws from each corner on the back of the handheld monitor.
    • Remove the casing from the back of the handheld monitor.
    • A nylon spudger may be helpful to pry the case open.
    • Using the angled tweezers, gently remove the plastic wire coupling connecting the speaker to the motherboard.
    • The power button may come loose as the case is being removed.
  4. Summer LookOut Duo Navigation Buttons Replacement: 4 단계, 이미지 2개 중 1개 Summer LookOut Duo Navigation Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the motherboard and monitor display together and set aside.
  5. Summer LookOut Duo Navigation Buttons Replacement, Navigation Buttons: 5 단계, 이미지 2개 중 1개 Summer LookOut Duo Navigation Buttons Replacement, Navigation Buttons: 5 단계, 이미지 2개 중 2개
    • Gently remove the black foam padding from the back of the buttons.
    • Using your fingers, gently lift the navigation buttons from the front monitor casing.
    • There are two sets of buttons: the outer navigation ring and the inner menu button.
    • The buttons are not fixed in place and will readily push out of the case. Use light force to prevent loss.
결론
작성자
3다른 기여자 명과 함께
Jordyn Looney
회원 가입일: 02/25/25
425 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 82
