주요 콘텐츠로 건너뛰기
Sunbeam Snow Cone Maker Dasher Replacement
필요한 것
  1. Sunbeam Snow Cone Maker Dasher Replacement, Dasher: 1 단계, 이미지 1/1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Dasher Replacement: 2 단계, 이미지 1/2 Sunbeam Snow Cone Maker Dasher Replacement: 2 단계, 이미지 2/2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Dasher Replacement: 3 단계, 이미지 1/2 Sunbeam Snow Cone Maker Dasher Replacement: 3 단계, 이미지 2/2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
결론
Thomas Falcon
회원 가입일: 03/24/15
107 평판
안내서 1개 작성함
University of Alabama, Team 1-5, Naidoo Spring 2015 University of Alabama, Team 1-5, Naidoo Spring 2015 회원
UA-NAIDOO-S15S1G5
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 23
전체 시간: 818
