주요 콘텐츠로 건너뛰기
Sunbeam Snow Cone Maker Motor Replacement
필요한 것
  1. Sunbeam Snow Cone Maker Motor Replacement, Dasher: 1 단계, 이미지 1/1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Motor Replacement: 2 단계, 이미지 1/2 Sunbeam Snow Cone Maker Motor Replacement: 2 단계, 이미지 2/2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Motor Replacement: 3 단계, 이미지 1/2 Sunbeam Snow Cone Maker Motor Replacement: 3 단계, 이미지 2/2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
  4. Sunbeam Snow Cone Maker Motor Replacement, Motor: 4 단계, 이미지 1/1
    • After removing the dasher, turn the device so that you can see the “lock” and “unlock” symbols on the back.
    • Twist the casing so that it is in the unlocked position and remove it from the bottom half of the machine.
  5. Sunbeam Snow Cone Maker Motor Replacement: 5 단계, 이미지 1/2 Sunbeam Snow Cone Maker Motor Replacement: 5 단계, 이미지 2/2
    • Unscrew the five screws and remove the piece labeled in the picture. You should now be able to see the motor.
  6. Sunbeam Snow Cone Maker Motor Replacement: 6 단계, 이미지 1/1
    • Lay the device on its side.
    • Remove the 4 gray rubber “feet” by pulling them straight off.
    • Remove the four 5.5 mm Phillips #00 screws that are under them.
    • Remove the bottom plastic cover.
  7. Sunbeam Snow Cone Maker Motor Replacement: 7 단계, 이미지 1/1
    • Remove the two 5.5 mm Phillips #00 screws holding a bracket to keep the cord in place.
    • Remove the the bracket so the chord has room to move.
  8. Sunbeam Snow Cone Maker Motor Replacement: 8 단계, 이미지 1/3 Sunbeam Snow Cone Maker Motor Replacement: 8 단계, 이미지 2/3 Sunbeam Snow Cone Maker Motor Replacement: 8 단계, 이미지 3/3
    • Remove the topmost two 5.5 mm Phillips #00 screws that hold the motor in the case.
    • Remove and replace the motor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kirsty van Dam
회원 가입일: 03/24/15
119 평판
안내서 1개 작성함
University of Alabama, Team 1-5, Naidoo Spring 2015 University of Alabama, Team 1-5, Naidoo Spring 2015 회원
UA-NAIDOO-S15S1G5
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,068
