주요 콘텐츠로 건너뛰기
Super Nintendo Cartridge Replacement
필요한 것
  1. Super Nintendo Cartridge Replacement, Cartridge: 1 단계, 이미지 1/2 Super Nintendo Cartridge Replacement, Cartridge: 1 단계, 이미지 2/2
    • On the bottom front corners of the cartridge you should see two screws using the 3.8mm "Gamebit" screwdriver bit. A 3.0U Spanner bit can also get them out.
    • Once the screws are out, slide the front part of the plastic casing down to clear the tabs on the top of the case.
    • The two halves of the case should open easily.
  2. Super Nintendo Cartridge Replacement: 2 단계, 이미지 1/1
    • At this point the game board and pins are freely accessible.
    • Here you can fully clean the pin set and inspect for damage to the circuit board.
    • Cleaning the pins is the easiest part; use a cotton swab and either a rich mixture isopropyl alcohol or Brasso. Other people swear by an eraser(the white kind), but it can lead to damage if you're not careful. Personally, Brasso works the best.
  3. Super Nintendo Cartridge Replacement: 3 단계, 이미지 1/2 Super Nintendo Cartridge Replacement: 3 단계, 이미지 2/2
    • NOTE: The top edges of the board are made asymmetrically so it can only go into the casing one way. Near the Blue Circles
    • Games with battery backup (allowing for save games to be stored in SRAM) allow access to the battery at this point for replacement. Most of the time the battery is a button cell: CR2032.
    • The battery is soldered in. You will have to break it out and re-solder the new battery in.
결론
To reassemble the cartridge, follow these instructions in reverse order.
다른 22명이 해당 안내서를 완성하였습니다.
BWest
회원 가입일: 09/02/10
3,375 평판
안내서 2개 작성하였습니다
OPEN OPEN 회원
Community
82 회원들
안내서 25개 작성하였습니다
댓글 한 개
Nintendo fix talk Nancy Places Nick III Fix SNES Alive Green
nj8324805 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 31
30일 전: 139
전체 시간: 34,174
