주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Super Nintendo Controller Port Replacement
필요한 것
  1. Super Nintendo Controller Port Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Controller Port Replacement: 2 단계, 이미지 3개 중 1개 Super Nintendo Controller Port Replacement: 2 단계, 이미지 3개 중 2개 Super Nintendo Controller Port Replacement: 2 단계, 이미지 3개 중 3개
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Controller Port Replacement, Eject Button: 3 단계, 이미지 2개 중 1개 Super Nintendo Controller Port Replacement, Eject Button: 3 단계, 이미지 2개 중 2개
    • Lift the right side of the eject lever out of the housing.
  4. Super Nintendo Controller Port Replacement: 4 단계, 이미지 3개 중 1개 Super Nintendo Controller Port Replacement: 4 단계, 이미지 3개 중 2개 Super Nintendo Controller Port Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
  5. Super Nintendo Controller Port Replacement, Controller Port: 5 단계, 이미지 1개 중 1개
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
  6. Super Nintendo Controller Port Replacement: 6 단계, 이미지 2개 중 1개 Super Nintendo Controller Port Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the ribbon cable from its port.
결론
다른 18명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
James Shirley
회원 가입일: 10/03/10
1,033 평판
안내서 2개를 작성함
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G47
4 회원들
안내서 25개를 작성함
3가이드 댓글
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - 답글 공유
This isn’t complete. How about taking the face plate off?
Daniel Powers - 답글 공유
Find don’t look like screws they look like rivets
Steve Pitcher - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 48
지난 30일: 226
전체 시간: 36,886
