이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
Carefully flip the unit back over.
Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
Remove the two silver 15.6 mm Phillips #2 screws on either side of the 62 pin connector.
다른 44명이 해당 안내서를 완성하였습니다.
댓글 4개
There are several versions of the Super Nintendo. Steps for my version are a bit different.
joshenders - 답글
This seems to be a newer super nintendo. If you have one of the older ones, there will be a bit more screws but still basically the same steps.
There are two versions of the Super Nintendo- the one pictured here, and one with a sound chip board behind the game cartridge reader. These two models have different shells that are not interchangeable (important to know if you're looking to buy a replacement housing for your SNES)
Gena FM -
It’s possible they may be referring to the European/Japanese version of the Super Nintendo/Super Famicom. Either that, or it’s one of the weird, misshapen “reskins”.
