주요 콘텐츠로 건너뛰기
Super Nintendo Power Switch Replacement
필요한 것
  1. Super Nintendo Power Switch Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Power Switch Replacement: 2 단계, 이미지 3개 중 1개 Super Nintendo Power Switch Replacement: 2 단계, 이미지 3개 중 2개 Super Nintendo Power Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Power Switch Replacement, Power Switch: 3 단계, 이미지 1개 중 1개
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
  4. Super Nintendo Power Switch Replacement: 4 단계, 이미지 2개 중 1개 Super Nintendo Power Switch Replacement: 4 단계, 이미지 2개 중 2개
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Cameron Deines
회원 가입일: 10/05/10
718 평판
안내서 2개를 작성함
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G47
4 회원들
안내서 25개를 작성함
2가이드 댓글
Any tips on how to tell if it's the power switch that needs replacing vs something else?
TopShopGames - 답글
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
Anders Hoff -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 25
지난 30일: 131
전체 시간: 25,593
