주요 콘텐츠로 건너뛰기
SuperSonic Matrix Mid SC-999 Camera Replacement
필요한 것
  1. SuperSonic Matrix Mid SC-999 Camera Replacement, Opening the Back: 1 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Opening the Back: 1 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Camera Replacement, Opening the Back: 1 단계, 이미지 3개 중 3개
    • Open up the back on the tablet.
  2. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Camera: 2 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Camera: 2 단계, 이미지 2개 중 2개
    • Locate the camera.
    • Unscrew the two screws.
  3. SuperSonic Matrix Mid SC-999 Camera Replacement, Unscrewing the Cover: 3 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Unscrewing the Cover: 3 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Camera Replacement, Unscrewing the Cover: 3 단계, 이미지 3개 중 3개
    • Use the J0 Phillps screw driver to unscrew the the two small screws on either side of the black peice.
  4. SuperSonic Matrix Mid SC-999 Camera Replacement, Opening Up to the Camera: 4 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Opening Up to the Camera: 4 단계, 이미지 2개 중 2개
    • Pull the black camera cover off and locate the camera with two gold bands running off upwards and to the right.
  5. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding Where the Camera and Motherboard Meet: 5 단계, 이미지 1개 중 1개
    • Follow the gold band the runs up towards the white and grey box connected to the green plate.
  6. SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Camera from Motherboard: 6 단계, 이미지 2개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Camera from Motherboard: 6 단계, 이미지 2개 중 2개
    • Use the wedge from step one to lift the grey box up.
    • The grey piece should open up towards you.
  7. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Camera Pt. 2: 7 단계, 이미지 1개 중 1개
    • Now turn your attention back the camera.
  8. SuperSonic Matrix Mid SC-999 Camera Replacement, Finding the Front Camera: 8 단계, 이미지 1개 중 1개
    • Next, Follow the second gold band to right to the white paper, or the front camra.
  9. SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Front Camera from device: 9 단계, 이미지 1개 중 1개
    • Now, carefully remove the front camera with the same wedge from step one, six, and eight.
  10. SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Back Camera from Device: 10 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Back Camera from Device: 10 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Camera Replacement, Unhocking the Back Camera from Device: 10 단계, 이미지 3개 중 3개
    • Use the same wedge used in step one and step six to go under the camera and carefully pry away from the sivler plating.
  11. SuperSonic Matrix Mid SC-999 Camera Replacement, Taking the Camra System Off the Device.: 11 단계, 이미지 3개 중 1개 SuperSonic Matrix Mid SC-999 Camera Replacement, Taking the Camra System Off the Device.: 11 단계, 이미지 3개 중 2개 SuperSonic Matrix Mid SC-999 Camera Replacement, Taking the Camra System Off the Device.: 11 단계, 이미지 3개 중 3개
    • When the camera becomes loose, gental pull up and out to the right to silde the gold band out of the white and grey box.
결론
작성자
3다른 기여자 명과 함께
Logan Robinson
회원 가입일: 09/18/18
493 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 167
