이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the J0 Phillps screw driver to unscrew the the two small screws on either side of the black peice.
Pull the black camera cover off and locate the camera with two gold bands running off upwards and to the right.
Follow the gold band the runs up towards the white and grey box connected to the green plate.
Use the wedge from step one to lift the grey box up.
The grey piece should open up towards you.
Next, Follow the second gold band to right to the white paper, or the front camra.
Now, carefully remove the front camera with the same wedge from step one, six, and eight.
Use the same wedge used in step one and step six to go under the camera and carefully pry away from the sivler plating.
When the camera becomes loose, gental pull up and out to the right to silde the gold band out of the white and grey box.
